brushlessboy16
brushlessboy16's Avatar
03.26.2009, 09:42 PM
check your output cup set screws/cvd setscrews. I had the same problem, and it ended up being a loose setscrew allowing the cup to rotate on the pinion. the screw hitting the edge of the flat spot was causing the noise
