speedemall
03.31.2009, 09:50 AM
Its still mod1. Mod1 or Module 1.0 is only the pitch of the gear teeth.
Use BrianG's speed calculator to calculate your top speed.. 45 should be easily achievable with low heat...
What pinion would you recommend I start with using the 46t spur?
