I finally got my emaxx running today after getting the MMM all set up. It was running awsome on its Lenhar motor. I had it running for about 3 minutes tops then it flipped over and idiot me didn't strap the 3s down (3s and 2s in series)and it popped out. I go to put it back in and my luck would have it its squishy. I take it to the work bench for a closer look and its a bit squishy but I am not 100% sure it puffed completely(I've puffed one of these before I knwo what it feels like). The wierd thing is it runs fine. Would I be risking too much to keep running or should I spend my $100 for a new air compressor on a new 3s?
I'm runnig nexxus. They are run by most of the local guys with no problem. It seems harder now i'll give it a shot. I'll let you guys know after the test.
PS: Does anyone know how to reverse the steering throw on a M8/M11? I bumped mine and now its running in reverse.
Reset the lvc to the correct setting manually. I like 16v for a 5s setup. As long as the pack does get hard after it cools off you should be fine. You may notice that it is more out of balance after a run than it was before. Just make sure it is completely balanced, as that may take longer than the charge...
Yea thats what I had it at(remember I asked you where to put it in a PM a while back) but I was having problems so I called CC. After 40 minutes on the phone the guy told me to knock it down to 15v or auto LVC.
'Fraid not, 15V is a little too low for 5S with modern cells. 16V will cut at 3.2V per cell, which is just right. :) You won't get any more noticeable runtime from a lower cutoff, and you risk damaging the cells.
Edit: Just noticed that Lincpimp got in there before me lol. The man speaks truth!
