Weak link in side by side pack's?
Sneeck
RC-Monster Custom
Sneeck's Avatar
Weak link in side by side pack's? - 12.13.2005, 01:07 PM
I'm chargeing my small fleet of side by side pack's at the moment, and I just noticed that some silver bar's get warmer than the cell's itself. Now as an electrician I know resistance ~ heat, so is it possible the solder joint's on that bar are bad?
The pack's are Corally 3rd generation race spec matched gp3300's(whateverthehellthatmeans) charged on a millenium pro at 4 amp's. They got heatshrink around them.
  Send a message via MSN to Sneeck
Dafni
Dafni's Avatar
12.13.2005, 01:32 PM
The bars on my batts don't heat up when I charge the packs. They only get warm from the batts, but they are never warmer than the cells.
Something must be wrong there. Did you check with a temp gauge? Is there solder visible, or is it some kind of spot welding?
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.13.2005, 01:55 PM
I solderd the pack's myself. Here is a pic with the heatshrink removed;
Don't got a temp gun yet, but I can feel it's slightly warmer than the cell's next to it.
Serum
Serum's Avatar
12.13.2005, 03:51 PM
Perhaps there is too much tin between the bars and the pack.. The trick is to get as little tin as possible between the bar and the cell
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.13.2005, 04:05 PM
No not much between the cell and bar's. The strange thing is that I just noticed this. Could be cause the pack's are sitting?(haven't used them since sept, keep charg/discharging them). Mayb a few time's cycling could fix it?
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
12.13.2005, 05:11 PM
as long as it isnt too hot, i wouldnt owrry about it.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
