ambryatim
04.02.2009, 02:43 PM
Sounds about right, the MMM will run the hv motor just fine. I would try your gearing and see how the temps are. As long as you do not try to run heavy/large wheels and tires you should be fine. If your emaxx has alot of al parts, or you run heavy batteries you may have issues, just keep an eye on temps...
Uh.....I have Moabs but I might need to get some Dirt Hawgs or Axial Terr-izers.
Dang, well I might have to go with something different.
