Go Back   RC-Monster Forums > Support Forums > General Nitro
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
04.03.2009, 03:39 PM
Originally Posted by MetalMan View Post
One of the biggest causes of pullstart failure is pulling the string too far. There's no need to pull it more than about 10in. from the base. Also, if the engine is really tight, use the flywheel to turn it over instead of the pullstart.
+1 and if the pinch is really tight even after break-in, heat the block up with a hair-dryer to keeps those hands from damage. It's not nice having your tune slightly off from the last time played and pulling for 5 mins on a cold block, ripped knuckles and blisters is what can happen heating up the block before you play will get you started in no time and save you some pain
I used to leave the truck (without body on) in the sun for half an hour while I was getting ready, heated it up enough to start with a couple of tugs.
I like it.......I LIKE IT ALOT!!!!!!
