04.03.2009, 10:32 PM
When you respond to a post, don't use the Quick Reply, use the Post Reply button. There, you can add attachments, but are limited in pic dimensions and file size.
If the OWB is good (should grab in one direction and not the other), then look at the little chrome pins holding the gears to the shafts. These DO snap under BL power. If this is the problem, there is a sticky made in the Revo section (made by yours truly) that describes the "pin mod".
