HB lighting PRO brushless makeover;
Serum
Serum's Avatar
HB lighting PRO brushless makeover; - 03.06.2005, 04:15 PM
On this picture you can see the problem of the lighting; The centerdiff is off center. To hold the batteriepacks in balance i decided to reposition the diff to the center of the frame
PURPLE?!?!?!? Used caustic soda to get rid of it..
Little bit of elbowgrease and some polish later.
Motorplate, from 4 mm thick aluminum
In the middle.. where it belongs... ;)
Here is the center repositioning device (CRD ©®)
And a nice support for the motor, to keep the motorplate from bending.
supermaxx
03.06.2005, 04:16 PM
GREAT SERUM!
I can't wait to drive it!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.06.2005, 04:22 PM
looking good! I was thinking of a similar solution to the off center center diff.
Serum
Serum's Avatar
03.06.2005, 04:26 PM
Works like a charm..
I am going to make a fourth mounting hole in it.
If you don't reposition that thing, you aren't able to position the batteries perfect.
RC-Monster Mike
Site Owner
03.06.2005, 04:30 PM
Yes, I know this! I had the same problem with mine. I haven't had the time to work on it in a couple weeks, but I was considereing the smae template to move the diff towards the center.
rc4x4nut
03.06.2005, 06:43 PM
That is beautiful. If only I didnt my my tickets to hawaii.
Mike, ygm.
Megazone23
Megazone23's Avatar
03.06.2005, 11:33 PM
Boy, it must be convenient to be able to fab your own parts when you need to! That's a nice conversion job.
One question, though -- what is that silver tape for?
Serum
Serum's Avatar
03.07.2005, 02:57 AM
I used the tape to align the centerdiff.
RCcarnut
03.07.2005, 08:13 AM
Nice work. The CDR looks like a happy face :L:
patch
03.07.2005, 10:51 AM
What chassis and center diff is that? I've heard of people using a ofna center also but don't know what model they are from..
patch
Custom extended aluminum chassis; UE idlers; Feigao 10L; 18.97KWF; 16 Matched GP3300; MIP CVD's; Custom rear driveshaft by RC Alloy's. Racer X shocks
Serum
Serum's Avatar
03.07.2005, 11:13 AM
It is from the HB lighting pro.
And true, i am also going to build an emaxx centerdiff with an Ofna diff.
Read the 2240 thread by Promod in the brushless section.
patch
03.07.2005, 01:25 PM
Found it, Thanks!
1 more question....it doens't say how you would make the brakes work. What channel would you use on the receiver.
patch
Serum
Serum's Avatar
03.07.2005, 03:26 PM
I am going to use a Y cable on the gas/brake channel. As simple as that.. ;)
Update;
Serum
Serum's Avatar
Update; - 03.07.2005, 05:08 PM
Well.... I haven’t figured out if i am going to use this things... Took me a lot of time making them, but they don't convince me... I got the material from a person I know. I didn't understand why it was so freaking hard to work on.. Appeared that it was used to make a Audi A8 bulletproof.......... Wish he told me before.. :D
The subtle motorbrace to be..
This took some work, it's the servo-holder, i needed to cut some of the nylon to make the driveshaft fit nicely.
And here is the new Battery Carrying Device (BCD ©) the battery is held on the aluminum plate with Velcro and a few tie-wraps The black things on the front are bumpers, that keep the batteries in place with frontal crashes.
In front of the long aluminum bars, you can seen the black parts i was mentioning. Those where a PITA to work on..
Megazone23
Megazone23's Avatar
03.07.2005, 05:23 PM
Careful using those Audi parts, you don't want your car to suddenly move forwards or backwards without any warning! ;)
