Originally Posted by crazyjr
I can also attest to the power of JBweld. I had two motors with separated rotors, a hv4400 novak and a 1200xl basic lehner (different times but same problem). neither had split, so i JB welded them and they held as long as i had run them. I still run the 1200xl to this day without problems, on 5s lipo. I used the standard JB weld , not the quickweld and the standard will hold to 600* if heat
The std jb is much better than the kwik.
You do need to let it cure for 24hrs or so, but it is near indestructible then...
