zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.09.2009, 01:06 AM
Yup, me and you are quite similar as far as knowledge on this subject goes, except you have a few extra sources I don't. Really appreciate you posting the link to that ISE, the DUO-Inverter! I haven't seen that thing in like 3 years, i thought they stopped making them. It would be awesome for a twin motor hot rod! And they say they can sell the motors separately from the controller?! MetricMind cannot do this, because of agreement with EviSol Europe, and now he is not selling them altogether.
Seen the Electric7.... that guy needs to open up the taps on that thing! None of that granny peddle foot he has in the videos.
Come on Lutach, you and I both know the cost and complexity of a car with 500 miles range and 200mph capable... no easy means about it. What motors would you use? DC brushless? That's the only way IMO, and super expensive LiPo cells, BMS, etc. I have some pipe dreams too, you know. ;)
Have you heard of Shelby Super Cars new Ultimate Aero EV they announced?
Now this is something else, they say they are putting twin 500hp motors, AWD, and 200 miles range... and then when it gets weird, 10 minute charging on a 110volt outlet??? Either they wrote a typo and haven't publicly addressed it, or they don't know what they are talking about, or the third possibility, and my personal preference, they have tapped some sort of unknown energy source, possibly from the zeropoint field vacuum flux?
There first announcement last year, they said it would be 'years' between charging... and now it's 10 minutes on a 110volt outlet? Boy, wouldn't that be nice!
http://www.gizmag.com/lithium-ion-ba...ugh-mit/11244/
Did you see my post a couple weeks ago on A123's new chemistry they are coming out with in the next 2 years? 100mah/g (so thats 7500mah cells compared to the 2300mah M1 cells they have now)... and get this, 170kw/kg power density (400C rate). These are twice the energy density of the best lipo cells available today, these will change the landscape of electric vehicles NO DOUBT!
Check out: http://www.uqm.com/propulsion_specs.php
If I had the money, I would use two 125kw units for 250kw, and only 180lbs.
lutach
lutach's Avatar
04.09.2009, 07:54 AM
My set up will use mainly components that are currently available for military use. The battery manufacturer on sells assembled modules to customer's spec with all the BMS and they can even do a charger, but I have my source for the charger. Price is up there, but it'll be a super car and the higher range tame version for everyone else will be much cheaper. Just need to catch some attention first. I'm not worried about SSC, I mentioned them to snellemin and most of the things they say, I've said before they even thought about an electric car. I've read about that new material those MIT guys made, but they have sold it to a company in Belgium so it might not be in a A123 cell. The cells that I'll be using can already achieve over 200C discharge, but I will never see that kind of discharge anyways lol. UQM is nice, but the problem with most of these new companies is that they are public traded and they think they have the best technology so their prices are up there. Imagine if I had a billion dollar in bailout money? I saw a GM wheelchair on CNBC yesterday and just thought it was a desperate attempt by them. Oh well, we can now see how our money is being used . This also proves to us that most if not all of those guys have no idea what they're doing.
zeropointbug
Z-Pinch racer
04.09.2009, 02:02 PM
BrianG, you actually DO need long range for high power, simply to get the power from a big enough battery.
It's not about a percentage of the max power for highway cruising, it's a specific Wh/mile based on rolling resistance/aerodynamics and to a certain extent, vehicle mass... with an educated guess on Wh/mile for the Ultimate Aero, I would say 220Wh/mile at 65 - 70mph, 220Wh x 65mph = 14,000 watts. 220Wh/mile x 200 miles range = 44,000kwh pack... assuming they use a voltage around 400 volts, 44,000kwh / 400 volts = 110 Ah. This is by not means difficult to do in a super car, this would be roughly 500 - 600lb. battery pack with today's lipo cells.
Lutach, that MIT battery tech was sold to two companies, one being A123, and the other was not stated, but most likely to this Belgium company you talk about.
I would love for you to post all this technology here so I can see it, rather than vaporware.
It's not simply about SSC bull$%&$*#! everyone here, from what they have said, that is WAY past the BS stage, it's a JOKE. So like I said before, it's either all a big sick joke, with the gun pointed at themselves... OR they have harnessed some exotic technology to make their claims real. Everyone laughed at them a few years ago when they said they would make the worlds fastest car, but look at them, they said they would do something, and then they actually went and did exactly what they said they would do, and then some.
Who makes these 200C batteries you speak of? I would love to know.
zeropointbug
Z-Pinch racer
04.09.2009, 02:10 PM
Brian, what car you referring to when you said use a turbine generator? It would be nice heck yah, but it would be loud. Regular piston generators can be had for a few grand for a 15kW unit, for my little car project this would be perfect, providing the highway cruising power is the calculated 8kW. These generators are quite efficient, and can run 100% continuously.
lutach
lutach's Avatar
04.09.2009, 02:16 PM
I think Jay Leno is working on one. Like you said turbines will be loud and it would also be a headache if the thing ever fails.
zeropointbug
Z-Pinch racer
04.09.2009, 02:41 PM
Well I know he has a Turbine super bike, ultra fast, and one the main features is it's able to melts bumpers behind you!
Also, Lutach, I can't find the EV inverters (Simoverts) on that link? I emailed that Magnet-Motor company on a quote for that S31 inverter, hopefully it's <$6000 CAN.... cross my fingers. I also contacted that ISE for a quote on the Siemens DUO, but IIRC, it's quite expensive, and not to mention it has dual motor outputs.
lutach
lutach's Avatar
04.09.2009, 04:16 PM
http://www.jaylenosgarage.com/cars/ecojet_shell.shtml
The link I got from my contact at Siemens, he said to get in touch with the Automation devision which is the one who makes the Simovert inverters. Let me know what Magnet-Motor says and if it's not the price you're looking for, I'll talk with someone who works there.
04.09.2009, 04:23 PM
Marine Turbine Technologies make the y2k bike you mentioned. I sat on the proto at a car show a while back. MTT is way down south here in LA. He has a few cars with the turbines in them, and does a ton of offshore race boats, fishing boats too. He uses demilled heli motors, IIRC, cheaper as they have maxed out their life expectancy in a heli, but are still good for ground use. I would love to ride that bike, 220mph min... My weak ass zx12r (only 154 hp at the back tire) can only do 195 (at least that is as fast as I have gone on it). I cannot imagine what a bike with 350+ ft/lbs or torque pulls like.
04.09.2009, 04:11 PM
No car that I know of. I was just thinking that turbines have fewer losses. Pistons have a lot more power-robbing friction. Also, turbines operate better at higher speeds, so I just figured if it was tuned for maximum efficiency at a certain rpm, it would be the logical choice. The idea is not to solely power the car from turbine-generated power, but to supplement it. If the car draws 30A constantly in highway conditions, and the generator provides 15A (or more) of current, it would extend the life of the battery pack considerably for the longer runs.
lutach
lutach's Avatar
04.09.2009, 02:12 PM
I can't mention who makes the cells as I would hate to loose my client. They make them for military use and thrust me they are robust. Have you contacted the Canadian companies that are in the industry? If I had the cash and the backing of a big company, I would take all my ideas off the drawing board.
Here is a German company that has a nice looking inverter: http://www.magnet-motor.de/en/home/p...r-electronics/.
It's the S31. They also make a nice little motor the M68.
