Problem binding Futaba 3PK to MMM -
04.09.2009, 09:46 AM
I have a steady green light on the RX and it is binded I think. I go to set up the ESC and full throttle turn on switch, get the solid red, then it turns solid green right away and when I go to full brake it blinks all the colors and the fan stays on. Any ideas? It worked fine with my Spektrum DX3s I am just trying to get it set up with my Futaba.
For others with a Futaba 3PK and a Spektrum module, make sure you reverse the Throttle/Brake setting in the 3PK before attempting to calibrate the radio with the ESC (otherwise it will not sync).
That was it I think. It finally binded but forward was reverse and vice versa. I just switched the settings as you said and I was good. Mine is the FASST module though and RX.
It helps to read the little manual from Castle where it says to reverse the throttle channel on Futaba radios .
Glad you go it all sorted out.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
