04.05.2009, 08:03 PM
allerc.com
skellyo
skellyo's Avatar
04.05.2009, 09:09 PM
Originally Posted by NoControl View Post
ok, Hey Linc think its pretty cool your doing all this, do you know what company makes the hyprion style balance taps, and or where you get them from? I wanna switch some zippys from xh to hyperion to avoid buying an adapter.
rclipos.com
cheapbatterypacks.com
NoControl
NoControl's Avatar
04.05.2009, 09:41 PM
I was refering to the white peice only, so i could pull off the old xh connector and replace it with the hyperion style and still use the original wires.
04.05.2009, 11:43 PM
Can't do that, the little pin plugs are different.
NoControl
NoControl's Avatar
04.06.2009, 01:07 AM
So it's either impossible or difficult to remove the xh connector, so that all I have is the wires, and the battery, then install them in a hyperion white connector without buying the "special" hyperion connector with wires or the xh board?
04.06.2009, 01:22 AM
The type of crimped on pin that the xh connector uses will not phsically fit and clip in a hyperion connector. You either have to splice the hyp tap on, or remove the shrink and solder a new harness on. I would suggest an adapter, cheapest and simplest way out.
NoControl
NoControl's Avatar
04.06.2009, 01:34 AM
Thanks for the opinion and yea it looks like I'll have too any ways, can't sem to find the hyperion style connector by itself.
Raze ST Truggy
04.06.2009, 07:43 AM
I have a i-max8 charger that uses JXT ballance tabs, and sometime last year picked up some used hyperion lipos from a menber here. I bought some addapters from hobby city that had a female JXT and a male Hyperion.
I think that JXT is the same as align when your looking for addapters. I also have a 2S MA pack that I also got used here (and btw: still works great) which has the same ballance tab as the 3S hyperion lipos that I have and with some pin moving/ shifting around I am able to ballance that with the same connector as I do the hyperions.
-Brian
snauty
04.06.2009, 06:49 PM
Hey linc i sent the lipos to you.
You should get them in 2-10 days.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.09.2009, 08:26 AM
I never posted pics of the pack linc just returned to me. It is in pristine condition.
I got some labels made too. Big thanks to Overkill for that! And Thanks Linc! It looks and performs great.
04.09.2009, 01:44 PM
Just took the shrink off a neu pack, 2s 4900 25c, and going by the numbers on the cells they appear to be enerland mfg. It does say made in china, but most of the newer enerland packs I have fooled with recently have that on the cells too...
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.09.2009, 11:03 PM
Mine by any chance?
04.09.2009, 11:15 PM
Mine by any chance?
Yep, should have them done and in the mail with the wheels by Sat morning at the latest!
snauty
04.10.2009, 11:16 AM
hey linc did you receive mine yet.
04.10.2009, 11:18 AM
Not yet...
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
