Thanks all!
Originally Posted by js058515
Can you post your exact set-up?
I am running an xray t2, novak slyder esc with 7.5 slyder motor and a 6.00 final drive ratio. loose ball diff front, spooled rear, 1 degree toe out front, 2 degrees toe in rear, -1.5 degree camber all the way around. The front shocks have 25 wt oil, 14lb srpings, 4 hole pistons and are positioned on the middle tower hole. The rear shocks have 25wt oil, 17lb springs, 4 hole pistons and are on the second hole form the outside on the tower. The tires are hpi t-drift.
