if tightened too much slightly, but as Mike stated there should be a wear-in period for the gears. I actually hooked them up to my dremel and spun them for a bit with the case tightened down and then backed off the screws a 1/4 turn or so and the binding was nearly all gone. Im sure it will get better with use as well.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
