Originally Posted by onetoo3
ok been lookine on here and this is what i come up with for the vendetta st
1/10 sidewinder
neu1107 or 1105 or a medusa need help with the motor will they fit detta motor mount
fp 3s 11.1v 1600 20c
thanks
The battery will fit, but you'll have to modify the battery space because it will be too tall. Everything else is right... Make sure to get the 28mm medusa if you get that.
If you go with 3s I would go around 4000-4500kv and if you go with 2s then go with 5000-8500... That is for insaine speeds. A 4000kv motor on 2s is fast. Look up some youtube vids....
And make sure to get the steel cvds! You want the ones that don't have the threaded shafts on them. You'll probably want ball diffs too, unless you shim the stock ones inside and out.
