05.07.2009, 09:53 AM
Так случилось? Я не вижу никаких проблем .... подождать .... это неправильно!
Gdot
05.07.2009, 09:10 PM
all this coming from stretched tvps
05.07.2009, 10:03 PM
Yes, my threads tend to wander, and sometimes they never get back on track...
Always Dreamin
05.07.2009, 10:39 PM
You think you'll ever finish the build?
05.07.2009, 10:42 PM
It is on my list of things to do...
Progress
Progress - 05.12.2009, 10:01 PM
So I got the other tvp cut, drilled a few holes and mounted the front and rear assys on. Looking good, and I should be able to get the tranny in tomorrow, after I cut the tranny and motor plate access holes.
05.12.2009, 10:31 PM
Looks good James.
Savage03
05.12.2009, 10:33 PM
Looks good! Say what hexes are those?
05.12.2009, 10:37 PM
Looks good James.
Thanks ladies!
The hexes are Dynamite, IIRC...
MetalMan
MetalMan's Avatar
05.12.2009, 11:34 PM
Nice, clean cuts. Wish mine were so sexy. Too bad you're gonna destroy those looks with a tranny.
Which body is that?
05.12.2009, 11:38 PM
Which body is that?
Just get a bandsaw and a few hand files... I may take some 100 grit on a da and smooth the edges a bit more, but I doubt it!
The body is the ford f650 body from proline. I think it is the one they sell for the cen trucks. 15" WB is a bit long,maybe 3/8" longer than idea for the body, but that is what the muggy center shaft gave me, and the lipo fits well too. Not too long, I doubt the flux 2200 motor will have any issues on 5s.
MetalMan
MetalMan's Avatar
05.12.2009, 11:50 PM
If I had room for a band saw, I'd have a mill by now . Aw, only 5s
05.13.2009, 12:42 AM
This is just a small truck... It will do fine with the 5s setup. Now the 5th scale savvy will have 10-12s and a 1527. I am also going to 10s and a 1521 in the 6x6 lst, and the baja will run 2 big motors on a 10s setup... That should be enough high voltage setups. I also have 2 mega 1100kv motors, and an aveox 36/38/2y, and a 10xl kb 45. So all I need are a few more hv escs and I will be good to go!
Joey
The Big Cheese
Joey's Avatar
05.13.2009, 02:03 AM
Wow thats killer... Love the scale. Ive gotta get some proper cutting tools...
05.13.2009, 02:21 AM
Thanks, it is just long enough to get an average lipo pack in front of the tranny!
Decent tools are a must, the band saw was only 100 bucks... And blades last a while if you keep them tensioned correctly. Good hand files are also a must have tool, I use the best I can find...
