twisted8
05.09.2009, 11:59 PM
Put 100k fluid in the center diff. That should help with the front unloading. It will not completely lock the diff, so turning should still be better over the solid center. The traxxas diffs only have 2 spiders, so you have to use thicker fluid than you would on an 1/8 buggy/truggy.
i thought it came from the factory with 500k ? it has what ever it came with in it.
