Patrick
Patrick's Avatar
05.19.2009, 06:02 AM
Originally Posted by Jason View Post
it is more used for 5s to 6s applications right ?
Only if you are pulling a lot more amps. High voltage will be less affected by a bit of resistance than low voltage, if your total power usage stays the same.
The size of wire you need is more related to your amp draw than voltage, and I doubt you will be able to pull enough current in a slash to really worry about bigger wires. I say leave it.
