Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Steve182
Steve182's Avatar
03.25.2009, 10:42 PM
Looks like some nice progress so far. Keep up the good work!
| Hyper 8 Pro- MMM, Castle 2200kv / Zippy 4s 5000mah
| Jammin CRT- MMM, Feigao 10XL, 5s Zippy 5000mah
| Savage Flux- Castle 2200kv Combo, 6s Zippy 4000mah
  Send a message via AIM to Steve182
ecoli
03.26.2009, 02:27 PM
Thanks for the replies guys. As for the battery and battery tray, will be ordering these through Mike. Just need to decide what battery I'm going with and then what tray I'll need. I'll also need to order some pinions from Mike too.
I've got lots of spare servos and a new rx for my DX3r, and am working on a deal for the MMM combo with the lhs (got to support your lhs when you can!). Just all needs to come together at some point!
Small Update:
Raze ST Truggy
Small Update: - 04.10.2009, 07:10 PM
I just swapped out the 36-60-2000 medusa for a 36-80-1600 Medusa in the buggy. The 60mm had a 12t pinion on it and a put a 20t on the 80mm. I wanted to see if I could make the motor sweat, after two seperate ~10min bash sessions of mostly speed runs the hottest I could get the motor was 120f. The MMM V1 is still going strong, and the 4000mAh 6S 20C Zippy didn't break 90f.
I'm going to go throught the diffs and add silicon lube and then I think that I'm going to sell the buggy with the 60mm and put the 80mm in the truggy.
-Brian
Always Dreamin
04.12.2009, 04:18 PM
Watching this build closely. Looking for a used but well taken care of buggy to convert myself. I have tried greased lightning to remove anodizing, with no luck... never tried easy off though.
Let me know if you get it off, I'd like to know how. - http://forums.thetoyz.com/index.php?showtopic=2539
As you can see from my post, i tried that stuff on Big bores with no luck...
jrandolph7002
05.19.2009, 12:50 AM
did you get done with your e raze.....i did one too i just got done with it...to me its heavy not as nibble as a t4...i'm running speed passions motor 2200kv and esc...2 batts from smc 5200mah 30c lipos
i have the batts stacked
i thinks its to heavy rolls over easy.fast i'm still tunning it.on the left side of the buggy is the batts in a rc monster tray ..then the esc
right side is servo, motor and then the rx.
i'm thinking of put one batt one this side to evan out the weight
ecoli
05.19.2009, 01:04 PM
Nope. Sold this project off to fund some other projects. Decided to go with a lighter weight buggy, but who knows when that will be. Too many projects, not enough time or money :D!
