I have a kyosho st-rr and Mike is making a chassis kit for me right now. I am going to use 2200 mmm combo on five cell maybe going to a 6 cell.
My question is what diff fluid would i use. I am thinking 15 20 5 front middle rear
I am mainly a basher. Keep that in mind. If i go to 6 cell I also dont want all the power spooling to the front wheels. What would you suggest for fluid. I also want to be able to wheelie.
I'm running a MBX5T as a basher with 30k in the middle diff and it's still too loose. The front end unloads easily and it's hard to get enough kick off of jumps to get a full backflip in before landing. The traction is especially bad on really loose dirt/dust.
I just ordered some 60k and 100k to try out. I'm thinking 100k in the center should really help out, and I'll probably go 30k in the front and 10k in the rear.
I'm using 10, 30, and 5K F-C-R on my ST RR running on 5S.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
going way up in the center diff would make the truggy not pivot as you tried to turn. kinda like a dump truck. if you bash just put in the thickest fluid you have. then buy another diff on ebay and set it up for racing. best of both worlds.
if you are racing why would you want all the power to unload to the front too? i Mean i know so so it dosent wheelie but i cant belive all of it. Was is a good number that i can bash with / wheelie but still be able to race.
awesoming, that much in the center! wow, i have a kyosho electric st-r, with 5-7-2k and i am can do wheelies off the line pretty easy. how do you prevent wheelies with such a heavy oil?
i ran 2650kv mamba Creation combo, 16t pinion, 44 spur, 4s 4000mah, weight 9.4lbs
So after putting 100k in the center I gave it a quick test run on and offroad today.
It still only wheelies if you punch it from a nearly dead stop on tarmac. It's much more fun on loose traction surfaces now, and it gets moving a lot faster. I'll probably put thicker fluid in the rear diff as well because it seems to be completely open right now, I might try 7k in the rear.
