NeuMaxx
Shock stand offs -
02.15.2009, 11:45 PM
My suspension is RPM arms, UE knucklehead towers and UE RacerX supershocks. The UE stand offs are 6mm but the lower retaining cup and spring rub on my 3.3 sliders. Where can I get a bigger stand off? I know this sound big but 10 mm would remove any cantact.
Supermaxx
02.15.2009, 11:50 PM
Have you tried putting some washers between lower rod end and arms? By the way, what arms are you using? You can also use M3 washers on the standoffs.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
NeuMaxx
02.16.2009, 12:13 AM
Thanks for answering Lito.
I have RPM arms. Washers may be the best answer, but a longer stand off would also put the shock more vertical. I am worried about to large a stand off being prone to bending.
02.16.2009, 03:17 AM
Axial makes standoffs, don't have a link  but some minor searching should turn something up.
NeuMaxx
02.16.2009, 10:47 AM
Thanks, I'll search....
If anyone is following this thread, Axial spacers:
http://www.axialracing.com/ftp/ax10o...s_spacers.html
Reason: post link
UE Supermaxx Addict!
05.21.2009, 08:54 AM
Also, the "6mm" is the diameter of where the shock goes on the stand-off, not the length of the stand-off, just so you know.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
RC Monster
05.22.2009, 06:21 PM
Hey Mark, let me see what I can dig up for you spacer-wise. I have a few different size Axial spacers plus some misc. others. However nothing quite 10mm though, I dont think.
I'll compare them with the stand-off's on my truck.
Check TCS, RCP, or maybe CKRC. Those are crawler vendors that usually have several different size's & color's of spacers. I think TCS has a "NN" hardware kit that may have the spacers you desire.
Let me do some researching this evening and I'll shoot you some links.
RC Monster
05.22.2009, 11:42 PM
http://www.tcscrawlers.com/TCS-Crawlers-mid-2-p-1.html
I am using my 10mm spacers to raise my steering servo on my crawler. I only have 1.
NeuMaxx
05.23.2009, 03:47 PM
Originally Posted by RCShocker
Thanks again Doug for the help. I am hoping to get some wrench time this weekend.
