D8 Driver
05.23.2009, 08:20 PM
Originally Posted by killjoyken View Post
Doesn't sound like you did anything wrong so I'm guessing manufacturer defect. I'd contact Medusa to see if they'll cover it under warranty.
He is right, it sometimes is a defect, because i had the same issue with a 36-60-2000kv medusa motor. iwas running pretty hard and slowed down, then coming out of a turn...a loud snap, i ran over to it and found the shaft snapped behind the bearing, weird huh? then i called them up and they said they would replace it under warranty, i only had for 2 months about.
05.23.2009, 08:22 PM
Your shaft broke in the same spot as mine.
