What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.07.2009, 11:27 PM
Originally Posted by littlegiant View Post
I wouldn't want to try using heat for fear of demagnetizing the rotor magnet.
I would not have tried hammering for fear of dismembering the rotor magnet!!!
I recommend buying a new rotor. With any luck you can find a used motor to pull one out of for cheap money.
06.07.2009, 11:28 PM
What size is it? I have both a l can and xl can motor for sale.
littlegiant
06.07.2009, 11:32 PM
Oh. It will be the kb45L cans. Gimme a price. :D
florianz
06.08.2009, 03:51 AM
I had the same problem, tried to get a 5mm shaft myself... well, of course it didn't work. then I wrapped the magnet with paper and ductape, and went to a company who are doing cnc-stuff and had it done there.
littlegiant
06.08.2009, 04:10 AM
u mean the company separated the magnet from the shaft and put in a new one?
Or did they just grind down the shaft output portion from 6 to 5mm?
florianz
06.08.2009, 04:33 AM
sorry... they grinded it down to 5mm. depending how cool the guys are they do it for a few bucks. in my case it was a bit difficult for them, cos the results of "my work" didn't make it easier for them...
I don't think that you can seperate the magnet from the shaft without destroying it. on the other hand, I had some loose rotors and glued them to the shaft.
