Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
lutach
lutach's Avatar
09.23.2009, 09:47 PM
Like those $200 JR hi-volt servos?
I'm sure they are well worth it, but most RXs still won't support over 6V to my knowledge- so that makes it a problem.
James, most any brushless fan will be fine up to about 75% over spec'd volts. And wow do they work. Buddy of mine has 2 2" BB fans rated 12V, run on 16.8 normally, and have been run at 25V, no issues. I have 2 1" Novak fans rated at 5V, running 8.4 for over 3 years. No worries!
I think the Spektrum Rxs can handle up to 9V
09.23.2009, 08:01 PM
whats a ubec? man, i am getting confused. i need to sit down and learn more about this stuff. i do have fans that i will need to run. i have always used y-harnesses in the past to run my fans. whats another way of powering fans with the ubec?
BEC=UBEC battery eliminator circuit or universal battery eliminator circuit. Most fans are 12v, you've already configured your setup for 6v fans, which is fine. With a 4s pack you could power the fans directly from the lipo pack. (they can handle a little over voltage.)
redshift
RC-Monster Square Tube
redshift's Avatar
09.24.2009, 05:11 PM
You'll need a gyroscopic thermocouple, and a passive resistor.
Direct or switched is fine. When will we see this thing in action??
big greg
09.25.2009, 12:47 AM
have you got the esc to power up yet?
KaztheMinotaur
KaztheMinotaur's Avatar
09.25.2009, 06:10 AM
I'm feeling the peer pressure now...
I worked on mine last night though. I go the wires and bullet connectors to the ESC.
Ryu James
Ryu James's Avatar
09.25.2009, 12:16 PM
gitter dun!!
Jammin SCRT10 Neu 1512 1y
Ryu James
Ryu James's Avatar
09.25.2009, 12:10 PM
well my plan was to get the esc all hooked up tonight since i have the bec and everything now but since my machinist finished the parts for my hubs i decided to work on the disc brakes instead. here are some pics. tomorrow will be esc day and test run without brakes. i need to order a couple of parts to finish up the brake system. probably gonna be another week to get the brakes finished but i will try to get a video before then. there are a ton of small, time consuming, mods needed to make these disc brakes work.
to make the disc brakes work i had some small aluminum blocks made that attach to the hubs and then the calipers attach to them. a few pics.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
brushlessboy16
brushlessboy16's Avatar
09.25.2009, 12:31 PM
so did you ever get that controller working?
florianz
09.25.2009, 01:53 PM
looks good
great built!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.25.2009, 04:37 PM
Brakes looks cool man.. Should be plenty of stopping power...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Ryu James
Ryu James's Avatar
09.25.2009, 05:28 PM
kaz, did you already get your brakes mounted? did you run into issues? its just one thing after another with these? i need to purchase some extended hexes cuz now the wheel hits the carbon disc before it even gets tightened down all the way. also the wheel hits the calipers so i need to grind out a little bit of material off the caliper or the wheels.
speaking of wheels i got my new outlaw 5t rims and hostile mxt tires today. they are sick!
as for the esc i am sure it works but i still havent got it all hooked up.
here are some pics of the new wheels/tires. and i think i am gonna stick with the rampage truck body instead of the desert rat 5t body. the ramp body is so much more aero-dynamic and i think will just be a bettery body. plus the desert rat body is kinda hideous. if the hpi 5t body wasnt so long i would use that. i like that body a lot.
Photobucket
Photobucket
Photobucket
KaztheMinotaur
09.25.2009, 09:37 PM
Yes. No, other than the binding I told you about.
I did discover that a 200 ounce servo pushing cable brakes seems a lot weaker than a 200 ounce servo running the stock Rampage brakes.
Wheels and tires look good.
I worked on soldering my battery connectors some tonight. I discovered that slip on pencil erasers make a perfect cover for 6mm bullet connectors.
Ryu James
Ryu James's Avatar
09.25.2009, 11:26 PM
hmm. yeah when i mounted my brakes on the stock plastic parts they worked fine, with the exception of needing to take out a little material to allow full steering throw. the aluminum parts are different in size and shape slightly so its been a little tougher. actually after looking at things again some extended hubs will take care of everything. they need to be extended by about 5mm on each hub though. i dont know if there are any that extend out that far. again i am using 24mm hubs. you know of any? i really like these uberRC hubs. i cant use the darksouls cuz they are round where the discs would be. so i need a hub that is hex shaped throughout.
http://www.davesmotors.com/s.nl/c.88...t.A/id.6349/.f
these uberRC hexes extend by 8mm which is perfect but they only sell them in a set so i would have to drop $200 and then try to sell the fronts. d4mn. didnt really feel like doing that.
Photobucket
10.19.2009, 08:43 PM
I rewatched the vid... The audio is seamless so I assume I'm seeing the video correctly?
To me most of the slow-mo seems "ratchety", that's why I called it a slideshow.
IMO a good vid would have 75% real time video and 25% slo-mo/stills/sweeps/what have you. Maybe 66.6/33.3 Definitely more actual truck noise. (frickin' youtube)
And according to many experts the average american attention span is about 3 min. I prefer about a 5 min. vid. I must be above average
I want a 5th scaler bad, my current projects have me busy for about the next 3 yrs., maybe after that.....
aqwut
aqwut's Avatar
09.26.2009, 12:15 AM
Looking good man.... Once your done, your Rampage will be worth a fortune.. LOL
