Mamba max heat problem
brushlessboy16
brushlessboy16's Avatar
Mamba max heat problem - 06.19.2009, 07:40 PM
THe mamba max in my rc10b4 is temping at 175 at the end of a 10minute run, the setup is:
rc10b4
Feigao 7s (5070kv)
21/86
2s lipo
start power high
timing (0)
no punch control or anything else.
I took some time to cut the air vents in my proline vortex body for some more cooling along with the front windshield.
It was originally geared 24/78 which i found to be really high, changed the pinion and spur to the current gearing, and the problem persists. The motor temp is 145 after a run and the batteries are at 95. what am I missing?
If I could wedge my MMM into the car I would.
06.19.2009, 07:59 PM
Try lowering the start power
e-mike
e-mike's Avatar
06.19.2009, 08:10 PM
also lowering the timing and add punch could help
and i think you overgeared no?
D8t on juice!!
brushlessboy16
06.19.2009, 08:19 PM
Been checking and rechecking the speed calculator- im geared for about 35mph with tire ballooning
timing is at 0 and punch is at zero, ill try start power and see what happens
Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.19.2009, 09:10 PM
Maybe the motor is on it's last leg..
brushlessboy16
06.19.2009, 09:39 PM
I doubt it, that thing runs like a bandit, perfect torque curve for the little car.
