06.24.2009, 05:02 PM
I would like to see some discharge graphs... Holding breath... Starting to turn blue... S..t..i..l..l..w..a..i..t..i..n..g
(falls on ground stone dead)
himalaya
himalaya's Avatar
06.25.2009, 12:16 AM
+1 on graphs. words just don't help too much here.
MA need to get themselves clear on basic concepts, they claim
"60C Burst - 2670 surge watts(405 amps) "
My question is: 2670 watts TO THE LOAD ?? or even half of that number?
....What a Blue Sky....
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.25.2009, 01:48 AM
Yah, you will never get that to the load (motor)... there is just too much voltage drop for a motor to suck the amps needed.
And what should also be noted, that even if you could charge at 15C rate, you won't be getting 1000+cycles from your pack.
These green packs, or a regular M1 A123 pack for that matter; should be considered a 15C/30C when comparing to your average lipo battery, performance wise. They can still handle the 30/60C ratings just fine however.
Erevocanuck
06.25.2009, 08:30 AM
On another forum they did.But it turned the graph was from only one cell connected to tabs(no wires or connectors)
