jocktheglide
01.06.2006, 12:15 PM
Originally posted by Sylvester
Good to here you got everything in there in one peice, as for the pins in the bulkless, if its too tight you may lose some performance in your truck as it will make the shocks work a bit harder, are you talking about the suspension pins or which ones?
the bulkless setup has two pins and they go inside the diff case dont know why you would need it, but those are a pain had to machine a bigger hole.
