Mini E-Revo Body,Wheels,Tire Options
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
Mini E-Revo Body,Wheels,Tire Options - 07.05.2009, 04:08 PM
Rims are HPI 35mm and have about 4-5mm more offset than stock.
FYI; The back of the rim where the hub is needs to be trimmed of about 1.5-2mm of material due to rubbing on axle carrier.
http://www.hpipart.com/?partnumber=HPI3031&c=95
Tires that fit these rims are Losi Mini LST tires, Have Zombie Maxxes mounted and they look tight. Other tires shown are Proline 2wd Rear Buggy tires.
Body is a Losi Mini LST also,painted with automotive Urethane BaseCoat. The body was a creative tight fit but works and look well.
I installed a Castle Sidewinder ESC and my temps fell down to barely above ambiant and motor stays cooler also.
skellyo
skellyo's Avatar
07.06.2009, 12:40 PM
I just pulled the radio, motor and ESC out of one of my VXL E-Revos in anticipation of installing my new electronics. I've got the Sidewinder, CCBEC and Spektrum SR3500 in hand. I just ordered the motor I'm going to try, a Multiplex Permax BL-480/6D. It's 29.5mm x 46mm and 2100kv. I've used one of their higher kv motors in a Mini Quake SE in the past and it was stupid overkill on 2S and never got warm. This should perform well in the VXL E-Revo. If it does as well as I hope, I'll be ordering more as they're much cheaper than a Neu or Mega, ~$70 or so depending on where you buy it.
Now I just need to get some street treads for it and see if I can keep it on all 4's.
07.06.2009, 12:55 PM
Just fyi, I have a couple of aveox 4 pole 28 series motors... XL cans, 2000kv, would be killer for 4-5s in one of these beasts, hell you could go to 6s if you like!
Semi Pro
Semi Pro's Avatar
07.06.2009, 04:32 PM
would a medusa 28-50 fit in the mini revo?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.06.2009, 04:52 PM
Yes, but the rear shock tower might need a little bit of a dremel trim to get it to fit.
skellyo
skellyo's Avatar
07.06.2009, 05:09 PM
There is no 28-50 Medusa. They make a 28-40 which will fit. Their 28-56 is too long even with grinding the shock mount.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.06.2009, 05:17 PM
Yes, A 56mm can long is way to much. That would interfere with the mount screws.
addicted2revos
08.06.2009, 07:26 PM
Sorry for the late post but what kinda temps are you getting outta the sidewinder?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.06.2009, 08:36 PM
I have a different motor now, 3300kv running 2s in Parallel w/the SW and my motor temps have yet to climb over 134F and the ESC stays ambiant temp Geared at 55/28. When running 3s the motor and ESC temps climb another 10F. These temps and gearing are what they are because I pretty much only run mine on the track.
Krawlin
Got brushless?
Krawlin's Avatar
08.06.2009, 10:04 PM
Actually with a Tenebol (I think that's the name?) big block motor mount, a 36-50 will fit and so will a 28-56.
Monster GT Conversion
Baby got new shoes
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
Baby got new shoes - 08.20.2009, 05:32 PM
After burning up a set of Bowties on and off the track thought I get something a little better suited for the occasional bash along with another set of BT's.
A more recent photo with a new motor, 3400kv Wanna-be NEU from HobbyCity, motor was 28.00 . Temps 120-130 even after several packs,ESC and lipos 2s stay ambiant 90+F
