Reduce brake strength to prevent endos, but its only at 25% correct? Sounds like you have it set for forwards-brake-reverse (near 0 rpms); you need to change that to forwards-brake-reverse with lockout (so it will only go to reverse once you've stopped, released the throttle, then re-engage reverse).
