CC/Neu heatsink?
emaxx 101
CC/Neu heatsink? - 08.09.2009, 07:23 PM
Hey guys, even with timing at 2, punch an 60% and start power at low geared at 18/68 my CC/Nue managed to reach 165f after about 15min (ambient was 75f) in my revo on 6s. Ive looked around but cant find a heatsink for a finned 1515. Maybe a fan? (BrianG you dont have to answer this question ). Any suggestions on how to cool it down?
revo guy
08.09.2009, 07:53 PM
if you havent yet cut airflow holes in the body
emaxx 101
08.09.2009, 07:55 PM
Yeah I have, in the front and back.
Andrew32
08.09.2009, 08:08 PM
change your gearing.
whats the temp of each of your components
ESC
Motor
Batt
emaxx 101
08.09.2009, 08:22 PM
Esc stayed around 140-150, motor was 165f max., batts were 110f.
The Dan
The Dan's Avatar
08.09.2009, 09:02 PM
Those temps are actually quite good. Considering you're running 6S, if it was my truck, I would be amazed to see the CC/Neu motor reach 165dF after 15 minutes of running.
If you do still want to lower the temps, drop your pinion gear down to a 16T.
big greg
08.09.2009, 09:06 PM
yup 165 after 15 mins is real good!
bdebde
That's All Folks!
bdebde's Avatar
08.09.2009, 10:25 PM
By timing at 2; do you mean 2 degrees? Or do you mean MMM setting 2 "normal"? In which case setting timing to "low" or "lowest" will help
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.09.2009, 10:42 PM
Yeah you wanting timing to be set at 0 for the lowest temps. Gear up if you want more speed. I have found that the gearing windows for these types of motors are very wide.
Area 52 Ranch Raceway
T.R.C.R.
emaxx 101
08.09.2009, 11:16 PM
big greg, I thought that the max. safe temp on the CC/Neu was 170f, or am i wrong? I would kinda like to just run untill my batts they run out (30 mins or so) without stopping to cool down because of high temps. Would this heatsink work? http://www.impaktrc.com/product_info...oducts_id=4036
Its 40mm and the CC/Neu is 41.78mm, think it will work?
Snipin_Willy
Snipin_Willy's Avatar
08.10.2009, 12:02 AM
Integrated fins on a can are almost ALWAYS more efficient at cooling. Using a heat sink on a CC NEU you would only be getting 1/2 of the contact surface area. The space between the CCNeu fins would just be void space filled with insulating air because it wouldn't be moving away from the motor.
15min at 165? Better than I can claim on really conservative gearing and driving. If you want better temps, change your gearing, your driving habits, or wait for cooler weather
nitrostarter
nitrostarter's Avatar
08.10.2009, 12:10 AM
Keep in mind that you ARE running 50,000 rpms in a MT...
Honestly, I say drop a tooth or 2 on the pinion, or drop the voltage.... Or get a lower kv motor.
N. Rustler conversion
The Dan
The Dan's Avatar
08.10.2009, 01:48 AM
170dF (175, to be el-perfecto) is the maximum safe temp for Novak HV motors, I remember from the dark ages when I ran those. Nah- for Neu/CC motors, 200dF is your safety ceiling. Always good to keep it under that, of course. And you've got plenty of wise advice from us here- your temps are great just the way you have it right now, exceptional in fact.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.10.2009, 01:49 AM
You could custom make a mounted side heatsink, that attaches with screws, and then goes up into a heatsink... should drop temps a far amount, maybe 10-15F?
Check Kershaw Designs, IIRC, he had something like what I'm talking about.
big greg
08.10.2009, 01:52 AM
i acually have seen one of these motors get to 220 and be ok, but yea keep it under 200 and your golden
