Kyosho 46T plastic spur on 8ight-T 1.0???
jsr
Kyosho 46T plastic spur on 8ight-T 1.0??? - 08.11.2009, 12:58 AM
I need a spur gear for my 8ight-T 1.0 I just got. I've heard certain spurs don't mate up well to the 8ight-T diff cup due to odd sealing between the two. Would the plastic 46T Kyosho spur P/N IF148 work and seal well?
Need to know quick.
Thanks!
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.11.2009, 01:26 AM
Yes. You will also need a kyosho O-ring to go with it or it will leak fluid. Part No. KYOORG06 at A-main Hobbies.
Area 52 Ranch Raceway
T.R.C.R.
Semi Pro
Semi Pro's Avatar
08.11.2009, 01:37 AM
46t will fit if you dremmel the chassis
44t will fit with no mods
jsr
08.11.2009, 02:03 AM
So it will seal perfectly with the o-rings?
I'll be using it with a Tekno chassis for brushless conversion, so the 46T should fit without cutting needed. Though, I might pick up a 44T also.
