DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.21.2009, 11:16 PM
Originally Posted by kazuaki View Post
OK, then next test will be a longer run with the Hyperions and then I will also try the Flightmax 2200's and see what they can do. Thanks for the idea.
One other thing I am wondering...could the EZRUN 60A ESC be holding me back. I wonder if it would go faster with an MM in there...
i'm one of those people that says you can never go too high a limit on amps for an esc. with lower voltage (ie: 3-4S), there are so many voltage spikes, that i would opt for a higher rated esc.
is this limiting your top speed? many would say no, but i'm not entirely convinced especially with the capacity of these motors. typically, in escs like the mambas or tekins if it was exceeding your escs capacity it would likely reflect in esc temps or damage but not having the ez run i couldn't tell you for sure.
Here's an exapmle: one of my friends got an RX8. he saw an increase in top speed over his 150A ezrun. was that the lone factor or was it a near perfect speed run? he says it's the rx8. only a data logger could say for sure with all other variables equal.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
