08.23.2009, 09:24 PM
Originally Posted by bcltoys View Post
Must have writing at the same time as you Neil will the hobby city batts cut the mustard in and erevo with the hv6.5 that weighs in at 13 pounds.
Wow, its like you travelled back in time and stole my setup from a few years ago....
The lipos will be fine, but you will find that the motor cant physically produce enough power to move the truck faster than about 25-30mph; all the lipos in the world cant make up for a lack of torque, so you have to geare down to prevent the esc melting from the high current draw; thats from directly compareable experience, so believe me when I say you need to either loose some weight off the truck (about 3lbs), or step up to a bigger BL system...
