Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.24.2009, 05:26 PM
Can you please please more specific about what Toy truck you started with ?
Thanks.
NickRummy
NickRummy's Avatar
08.24.2009, 11:05 PM
Thanks.
Are you referring to what truck the chevy body came from? If so, it's a Jesse James West Coast Choppers Chevy Silverado. I'm not sure exactly who makes it.
EDIT: I didn't really start with any truck in particular. Just knew I wanted something big. So I got that body first, got the axles because I knew they would hold up to some punishment then started fitting everything together after that.
08.24.2009, 11:32 PM
Damm those are sweet motors....
nitrostarter
nitrostarter's Avatar
08.25.2009, 12:44 AM
Some serious brushed power there!! Looks great! Clean build.
As for the tranny, the 3905 tranny is much stronger and will handle the power better than the 3906 tranny. If you were going to make the plates, I would definitely do the swap.
N. Rustler conversion
NickRummy
NickRummy's Avatar
08.25.2009, 08:32 AM
Is there anything that needs to be done to the 3905 to beef it up or are they pretty stout stock?
08.25.2009, 08:47 AM
A steel idler is about it...
NickRummy
NickRummy's Avatar
08.25.2009, 09:37 AM
Does it use the same idler as the 3906?
08.25.2009, 10:21 AM
Sorry ignore me - I had by 3906 and 3905 mixed up as i was looking at your pic...
3905 is supposed to be fine as is...
NickRummy
NickRummy's Avatar
08.25.2009, 10:30 AM
No problem. I never knew why they made the part number for the new truck smaller than the older?
NickRummy
NickRummy's Avatar
08.25.2009, 01:54 PM
I hope you guys like pics I didn't bring the camera with the video... I probably won't take any video until I get the trans sorted out. No one enjoys hearing that noise.
Took it to the rocks to see how it would do. The transmission complained quite a bit but other than that it had plenty of power with the current gearing and the suspension seems pretty stable. Center of gravity was a lot better than I thought. I'm not running any foams at all in the tires. Sometimes it's ok and other times it's not, mainly when there is a heavy load on one tire. I think I'm going to have to modify the stock foams and put them back in. Anyone know of 3.2" beadlock wheels with 17mm hexes? Full offset preferred. There weren't to many places it wouldn't go. No real challenging climbs.
Then it was over to the baseball field for some low traction high speed testing! They didn't mind me running for a few minutes.
You can definitely see the need for foams when running wide open.
To much fun!
08.25.2009, 02:01 PM
maximizers... 1/2 offset...
http://www.rcplanet.com/Maximizer_17..._p/max1731.htm
Foxracin
08.25.2009, 02:03 PM
Maximizers are 3.2 and 17mm. They have zero and half offset. I got a set currently coming in the mail so I will let you know how they work.
http://www.maximizerproducts.com/
Love the pics man. I like the one in your avatar with the tire rolled over.
Foxracin
08.25.2009, 02:04 PM
You beat me to it Arct1k. lol
NickRummy
NickRummy's Avatar
08.25.2009, 02:13 PM
Man and to think I actually ran those exact wheels on my LSP for a while too.....
Does 1/2" offset mean that the hex is basically flush with the back of the wheel?
rim offset
chrismechanic
rim offset - 08.27.2009, 08:11 AM
hi all... half offset is half an inch wider i.e the rim sticks out half inch more per side and gives you a more stable wider truck, maximizer bead locks are good strong rims ive now had 2 sets and very pleased with them, nice build
