Originally Posted by schofield
would a traxxas VXL esc be able to handle a 775 drill motor and a spc 2s lipo?
in a t-maxx with an E-maxx(old) tranny locked in 2nd. diffs and drive line are taken care of. what is a good gearing range? here it is now.
thank you
The ESC should be fine, they list no motor limit for either a 540 or 550 motor. The higher voltage the motor is rated for the easier it is on the ESC. Basically the higher drill motor you have the higher turns it is and the lower the Kv.
Jeff
