simplechamp
simplechamp's Avatar
09.07.2009, 11:56 PM
Thanks, next question: what is the purpose of the new bearing you've fitted on the cap/spur side of the diff?
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
09.08.2009, 11:35 AM
The 8X12X3.5 bearing is simply to center the TRA3985X output gear perfectly on the spur/cap. An 8X12 bushing would do the same but I couldn't find one so I went with the bearing. It will not move or turn so even an old gritty bearing will do fine.
No brain, no headaches.
