Unsullied_Spy
Unsullied_Spy's Avatar
09.09.2009, 05:47 AM
Jato trannies are very weak. The Rustler tranny is tougher because it has steel gears (even though they are smaller pitch). I've seen people putting an 18T pinion in the tranny in place of the stock 17T and they said it meshed better and held up to a ton of power.
J57ltr
09.13.2009, 09:07 PM
I guess I'll look into this. I bought a JAto tranny a while back and thought about removing the center dif in my Lightning 10 and mounting the trans sideways. I want to keep the 2 speed but will have to use the mechanical brake and won't have reverse, but I want to set it up for top speed runs. I am not going to lock it into just second. Some people think that a 2 speed is useless for electric but I think it will keep the current draw down and allow me to keep the motor rpm's down.
What is the pitch on the Jato trans.
Jeff
whitrzac
Can't catch this...
whitrzac's Avatar
09.13.2009, 09:17 PM
Jeff
I thought that too, but the stock tranny WILL blow when it locks into 2nd...
J57ltr
09.13.2009, 09:32 PM
Care to splain? As I see it by the time the trans is going tro shift the power is going to be down as opposed to a nitro, so when second hits the motor will peak again, but then power will start dropping again as rpm's increase.
I do understand that the lower the overall ratio the weaker it is.
I don't know, I'm just asking.
Jeff
