brushlessboy16
brushlessboy16's Avatar
09.15.2009, 09:42 PM
Rpm directly corrolates to speed.but these two cannot be directly compared because they use different kv motors and differenent gearings.
Torque is based on Kt or oz/in per amp of power. In most cases Kt and Kv are directly related..
*in most cases*
-A motor with a higher Kv will have a lower kt
-a motor with a lower kv will have a higher kt.
So running a lower kv motor (with a higher kt) on higher voltage results in a torqueier power system.
hope this helped
