Hong Nor X1 CRT!
DonovanP
Hong Nor X1 CRT! - 09.18.2009, 04:32 PM
Hi guy's..New to the forum and thought i'd share my latest creation!Swapped this roller pro kit for a savage 25.Was in perfect condition and only used at one NATS last year..
Running 80amp EZrun combo with 3665 2300kv motor.Using Intellect 4600mah 20c lipo's..Had all of this in my e-savage and was just to powerful and got fed up with snapping shafts and diffs.E-savage RTR was round 4.45kg and the truggy is just over 4.3kg.So its light!In my e-savage with this setup temps was round 50-80deg F on ESC and 70-100 deg F on the motor depending on conditions and air temp.So it ran nice and cool so should work just fine here!
On to the pics.
Mock up.
Custom motor mount.
Everything fitted.Wiring still a mess but its sorted now.
DonovanP
09.18.2009, 04:34 PM
New body painted.
Let me know what you guy's thing..Greetings from South Africa.
DonovanP
09.20.2009, 02:19 PM
No comments??
Jabe
09.20.2009, 02:54 PM
Nice mount, i specialy like that "extra" mounting point in front of motor.
MetalMan
MetalMan's Avatar
09.20.2009, 03:13 PM
Yeah, that extra mounting point is a nice touch! Should help to keep the motor mount from bending in a bad front end collision. Nice work!
DonovanP
09.20.2009, 03:56 PM
Thanks guy's..The mount is solid for sure..
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.20.2009, 04:30 PM
Looks great, wise idea installing the set up in the more durable truggy platform. You should have a lot more fun to because the truggy will handle much better also.
