Emaxx_Quebec
Emaxx_Quebec's Avatar
09.23.2009, 05:38 PM
Originally Posted by bryan View Post
I had the same problem about 1 month ago.i removed all castle files from my computer ,re-downloaded and problem solved. Mine also would not recognize reverse durring calibration
I'll try that
Emaxx_Quebec
09.23.2009, 05:52 PM
Still not recognize reverse ( break) when calibration
firm ware 1.22
bryan
bryan's Avatar
09.23.2009, 07:15 PM
Do you have access to another computer ? I honestly do not think that its your esc. I could be wrong.try downloading the new firm ware 3.161 or whatever it is."look for errors before you finish"
Emaxx_Quebec
Angry 09.25.2009, 10:08 AM
Not fixed yet.
When I reverse the trottle to normal position on the Futaba it go backward and the red light is on on the MMM.
Still can't breaking with the transmitter.
How can I tell if a Futaba sending signal?
Steering:OK
Trottle: OK
Ch3: OK
Break ( Reverse): Nothing
I'll try another radio tonight
Emaxx_Quebec
09.30.2009, 09:14 AM
I just got time to work on this issue.
It appear that it'll not bo the MMM.
I tryed to calibrate the MMM with my old TQ3 and it worked perfectly.
So it'll probably be the Futaba 3PM.
I'll give you news.
Pdelcast
Pdelcast's Avatar
09.30.2009, 11:10 AM
I'll give you news.
Emaxx --
Sometimes the easiest way to fix a radio problem is to plug a servo into the throttle channel, and see what the throttle is actually doing. This way you can visually confirm exactly what the throttle channel is doing. This makes programming the radio a little easier.
Patrick del Castillo
President, Principle Engineer
Emaxx_Quebec
09.30.2009, 11:21 AM
When you say to plug a srevo( steering) in the throttle chanel, you mean once mmm is on or before open it.
When I hook up a servo to the throttle channel to see if it is working correctly, it would not even arm. ( normal I think since the MMM is hook to ch1)
