Pdelcast
Pdelcast's Avatar
10.02.2009, 01:58 PM
Originally Posted by scarletboa View Post
what is the difference between the v3 and v4 mambas? if i get a MMM right now, it'll be a v3 and not the newer v4. will there be the same policy with the v3s that there was with the v 1 and 2? if my v3 were to fail, say, 14 months after i get it, would i be able to exchange it for the current model? or was that only with the v1 and v2 due to the high failure rate?
The V3/V4 are fairly similar -- same boards, slightly different parts. Any V3 that gets repaired also gets upgraded to V4.
There really isn't enough of a difference to make it worth while to return a V3 for the changes.
Patrick
Patrick del Castillo
President, Principle Engineer
