Did you already try it ?
Castle Link:
- Bug preventing some nationalities from being able to run Castle Link correctly has been fixed
- No longer have to 'Run as Administrator' to store your default motor-pole / gear ratio setup
Castle Link Graph Viewer:
- Added ability to display temperature in degrees C or degrees F
- Added ability display actual head-speed or prop-speed by entering the gear ratio
- Removed menu items to select individual data-curves, instead simply click on the label below the graph
- Added a 'How To' help menu option
- No longer have to 'Run as Administrator' to change your motor-pole / gear ratio or temperature setup
Source
