SV6000
SV6000's Avatar
10.13.2009, 02:47 AM
I have two schulze and i think they are terrific.
If you are getting a lot of glitching and weird movement it is more than likely something to do with the radio setup and binding to the ESC.
The 18.97 Is not built for 6s and will not work with it. It will apparently shut down. The 18 cells they quote from the website is 18 cells under load ie 5s
I know for a fact that they do not recomend running a bec with the new schulze speedys (its in the manual) instead they prefer you run a receiver pack.
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
Tags
6s lipo, bec, neu motor
