snellemin
2 KiloWatt RACER
snellemin's Avatar
10.28.2009, 11:46 PM
Well the 3.19 didn't update my two mamba max's, that's why I asked.
I kinda like dragbrakes, as I lose brakes at time with high kv motors and the dragbrakes always work. Work around is to lower the brake epa a bit.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
etc1006
10.29.2009, 12:13 AM
And I guess it won't do Vista w/ the MM yet?
10.29.2009, 08:48 AM
It works perfectly now with both Vista 32/64 and Windows 7 32/64 - Hats off to the guys at Castle for making that magic happen...
To get the MM to work with Windows x64:
1) Install software as Admin on x64 AND an x32 machine
2) Flash MM to lastest firmware using x32 machine and normal USB cable
3) Connect MM to x64 machine using castle link
4) Send a Pizza to Castle Support and Engineering desks
5) Sleep easy...
thzero
10.29.2009, 11:57 AM
Ah! So that's the trick... didn't think to try it after I updated it on 32-bit XP.
5) Sleep easy...
