can i drill out the side of a 6.5mm bullet connector will that work or would it be a waste?
when i shorten my motor wires on the cc 2200kv do the wires have to be the same length?
Just drill/cut ONE side out, that way you have enought contact surface.
That's what I do and it works great. I've never done a ful 90*, but sometimes I make a 45* angle and it's a good compromise between an angled connector while still allowing me to get a single piece of heatshrink over it.
so instead of making it 90. just grind out the bullet so i can angle it around 45?
and what about cutting my cc2200kv motor wires do they all have to be the same length?
Reason: im slow
...and what about cutting my cc2200kv motor wires do they all have to be the same length?
Ideally, they should be, but I personally do not think it matters if there are slightly different so that they reach where they need without stress or too much slack. Mostly aesthetic.
