wich ESC/motor
HootMaRoot
HootMaRoot's Avatar
wich ESC/motor - 11.01.2009, 11:18 AM
i am looking into converting my TTR ER-1[1/8 scale TC] from nitro> BL
but i amnt sure on what system to get i had been looking at the speedpassion silverarrow ESC/3.5motor but that was till i noticed it was sensored setup, and have noticed the sensored motors are a bit more pricey compared to unsensored motors
i have had a look at geting the castle MMM but am now having trouble on finding unsensored motors of about 4500kv > 6000kv
if anyone can advise me on wich ESC/motor to use as i am new to the electric side of things and since BL seems to be a lot more reliable and faster than nitro
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.01.2009, 12:34 PM
Why do you need such a high kv motor for? General rule of thumb is you want the brushless motor to spin about the same speed as the nitro motor that came out of it. I don't know the setup on the car you mentioned but I'm sure it's similar to most 1/8 vehicles. Your going to want to run at least 4s if not higher for efficiency. At 4s something in the 2000-2200kv range is generally used, 5s 1600-2000kv, 6s 1300-1800kv. A 4500-6000kv motor in a 1/8 would need to be geared with about a 5-6 tooth pinion to be useable without pulling enormous amps on start up
HootMaRoot
HootMaRoot's Avatar
11.01.2009, 12:54 PM
i had been advised to use a higher kv motor as its for a TC/onroad RC. and with the higher kv i could use a 2S or 3S lipo to save a bit more weight. if i was to run a high kv motor i guess i would need a lipo with a very high C rating then ?
the nitro egine that came out was a thundertiger pro .28BXr max RPM of about 35,000. i was also running a 13t/15t and once a 18t clutchbell
11.01.2009, 11:50 PM
Need more info on that vehicle (size, weight, intended speed etc), and pictures, then some better advice on precise setup can be given
simplechamp
simplechamp's Avatar
11.02.2009, 06:33 PM
The SpeedPassion 1/8th Silver Arrow ESC has gotten quite a few bad reviews from what I've read. Lots of "Blew up on the first run" situations. Supposedly a V2 is going to be (or has been) released that fixes the issues, but I haven't really followed them at all.
Stick with a MMM or Tekin system and you can't really go wrong.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.02.2009, 06:55 PM
I run a 4000kv motor in my 1/8 onroad conversion with an Tekin RX8 ESC. It's plenty fast with 4s2p A123 pack. A 4s lipo would be alot quicker.
I'm assuming this is the car in question Thunder Tiger ER-1
Wheelbase(mm / in.)13.2" - 13.6" ( 335 - 345mm )
Weight(g/ lbs.)112.9 oz. ( 3200g )
Length(mm / in.)22"-24.8" ( 560 - 630mm )
Width(mm / in.)10.4" ( 255mm )
Height(mm / in.)5.51" (140mm )
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
HootMaRoot
HootMaRoot's Avatar
11.03.2009, 02:11 PM
yup thats the one thunder tiger.
i have been looking at the RX8 ESC its a bit more than i wanted to spend on it but had a couple of ppl say its good.
snellemin what sort of gearing are you running on your on road conversion ?
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.03.2009, 02:15 PM
My gearing currently is 51/20.
