rootar
rootar's Avatar
11.05.2009, 01:48 AM
little update i made two aluminum spacers to fit under the Center diff mounts and im now using an Associated Plastic 46t spur gear on this car, it bolts right up to the xray diff gasket and all, youll need to properly shim it, which took one extra shim under the bevel pin on the spur for me, and youll need to use an rc8 o-ring on the spur as the xray one is alittle small in OD..
btw if anyone needs a few rc8/sc8/rc8t plastic spurs gear i have about 40 of them in 46t, 48t, and 50t it really makes the car nice and quiet! But with the shims under there i can also use my slipperential if i take it out of my truggy.
