Scott711
Scott711's Avatar
02.01.2006, 12:26 AM
Did you disconect the motor from the driveline? You need to do that to test for cogging. You could just pull the pinion off. If you have then I would say you have some cogging or something dragging your tranny. I just did a test similar to yours with mine and it free wheels very fast with the pinion removed but goes about the same as your with the pinion still attached.
