- UE diff (6 spyders) with black anodized cases
- UE Monoblock black anodized
- Proline Ford F-650 body
- IMEX Swamp Dawg tires
- Turnigy 4500mAh 3S2P 30C LiFePo4 packs
- and some minor mods...
I made an Excel file in which I listed all the parts needed to build this maxx (screw by screw, bearing by bearing, washer by washer...), where to buy them and how much they cost. PM me with your mail if you want it.
wouldn't mind some new vid's also... about to take a break with my 5th scales now and get back to my e-maxx's. I think a flm chassis might be next. love your truck, great build.
Thanks Ron
These little maxxs are great
You can't go wrong with a FLM chassis ! I hope my file will help you. I will make a vid asap !
________
"Some" build pics !
The first step was to anodize some parts in black to match my color theme. It's 1offRC (http://1offrc.com/) which did it, they made a great job and their service is excellent !
The Monoblock didn't fit well the FLM 3905 chassis, I've had to dremel a bit the 4 bottom screws (chassis braces side) of the Mono and the rear notches of the chassis :
I needed a longer center rear dogbone, the UE "DogBone for Monoblock with the Thunder or Lightning Chassis" fits but it's a tad shorter IMO. The O'Donnell dogbone is longer but I use the UE one which seems stronger. I will test both though if needed.
I replaced the FLM drive cups with the Traxxas Drive Cups Inner Revo (5153R) which are longer. And I use HPI rubber O-rings to secure the dogbones.
Second step was the assembly of the UE diffs. As I use the stock driveshafts (I will use the Summit ones if the stock ones don't hold out 6s), I needed to replace the UE output drive cups (on top of the pic) by Traxxas stub axles (I cut the threaded part) :
I use Ofna diff oil (7k front & 5k rear), Acer Racing bearings and Gorilla Snawt (for ring and pinion gears). And voilą ! :
It was really long to shim them, I hope I did it correctly
