there is the problem, i cant gear up 63/26 is the best i have found
losi makes a 59 tooth spur but the motor cant get close enuf to mesh right (it hits the transmission) and i havent found a place that makes over 26T pinions in 6mm
I brought a custom made 30t from Dan ,it was 5mm thou ,he must be able to do them in 6mm ,you would think. http://kershawdesigns.com/
